Johnson venom 225 HELP
Fkwarren
Have a 96 Johnson venom 225 outboard.
motor burned a piston and has been sitting for 2 years. I just did an overhaul and replaced all the Pistons with new ones. Also replaced needle and seats in all carbs and cleaned them. Starter was weak so I replaced the starter. Now I have 2 issues.
#1 I cannot get it to run. All the cylinders have good and equal compression, the carbs all have fuel in the bowls, but it acts like it's not pulling enough vacuum to pull fuel out of the bowls. All the Jets are clear and open. It did start on starting fluid one time, but I don't want to use that again and risk damaging anything. Problem#2 is the starter will spin fast then slows down dramatically after a few revolution. Batteries are good. Motor is not seizing. All that was checked. I wondering if I have an electrical issues, or if my new starter is going bad.
Any suggestions on what to check for on the fuelling issues? I am a mechhmec,but have limited experience on 2 cycles. Any help is appreciated.
Honorary Supreme Mariner
Are you pushing the key in while cranking it over ?-----Factory starter or something that is " just as good " but cheaper ?
boobie
Are all your connections from the battery to the starter good, clean and tight ??
Fkwarren
Yes I have tried pushing key in and not. Starter ordered off Amazon, I looked it up by part number and it was shipped thru a marine supplier, but I'm not sure if it's a good quality or cheap
