New Zealand....well.....that sort of changes things a bit. I have read many posts from guys from AUS and NZ, and it seems there is a common thread. The cost of parts and for that matter, the cost of a whole engine is extremely high. So much so that you guys want to keep your gear running any way you can. (Good ol' Durban comes to mind.)
I hope that is accurate. That's what I get from some of the posts....
Anyway....the 88 driveshaft is a one piece deal, with an o-ring at the top that seals the crank to driveshaft joint. No o-ring, and you rust the splines and then the LU is stuck and cannot be removed.
The botttom end of the crank on the 88 is plain splined opening, nothing special.
The 92 DS splines are the same in size, count etc. as the 88, but the length is different, and the o-ring does not exist on the end of the driveshaft. The o-ring is captive in the end of the crankshaft, which also has a hardened chrome sleeve pressed over the end.
To keep your gear running, considering your location, I would look very carefully at the tops of the driveshafts for both years.
See if you can figure out a way to seal that DS to CS joint. If you put the 88 driveshaft in the 92 crank end, the o-ring would lie on splines, and never seal. Also, (this is iffy, from way back in my memory), the 88 DS is just a touch longer, and when assembled, LU, midsection, and powerhead, the top of the DS will bottom out in the crank putting "squeeze" pressure on the whole assy. That can easily be eliminated by shaving off the top of the 88 DS about 1/4" or so.
You can do this with careful measuring, some innovative ideas to rework the top of the 88 DS, etc.
On the 92 CS...where the bearing is seized at the top, you can definitely turn that down and sleeve it up to nominal size. The bearing is available separately from aftermarket suppliers (not available from Evinrude). You can get this bearing from promarineusa.com. Press the old seized one out, and press the new one in. I really don't think there is a whole lot of stress on the upper bearing surfaces, at least not like the center bearings and the rod bearings. I bet sleeving that top roller surface would work just fine, and keep you going even tho it is not "corrrect" as far as repairs go. I just had a thought...your '88 upper crank cap with bearing will also probably work.
Good luck.....maybe Fazt will jump in here and comment....all this is kinda speculative on my part. He may know something that will add more light to the question.
