Johnson V6 mix n match
furyimp
I have a 1986 225 (small bore) engine that has severe bore damage and a pal has a '92 225 that has seized the top bearing. The crankshafts look to be the same so I'm planning to fit my shaft to his block My old engine has an earlier version of VRO and I'm concerned about the earlier carbs running on the 3 litre engine .Are there carb differences that would make such a plan a bad idea. My friend fitted a remanufactured powerhead to his engine and says I can have the remains of his for free.There must be a fishhook somewhere. Can anyone offer any advice? Thanks
daselbee
If you are going for the crank only, then the answer is no, they are not the same. There is a significant design change in the bottom end, in that there is a chrome sleeve over the shaft end, and there is an o-ring captive inside there. The top of the driveshaft for the 92 crank doesn't need the typical o-ring,so your lu will not fit/mate properly with the DS at the splines. It may fit, but it will not be correct, and I think that there are DS lenght issues too....
furyimp
Well that answer seems to have torpedoed the plan.I understand damaged cranks can be restored with a sleeve but is seems I would still run into a driveshaft length problem as well if I tried to repair my friend's whole engine, unless you can think of another way out, Thanks
daselbee
So you get a crank from a 1992 up (434771 pn) and repair the 92 powerhead. Those cranks were even used in the v6 Fichts (200, 225, 250). and there are plenty of those around that are blown up. Then you can use his whole engine, or put that powerhead on your midsection, and use his lower unit....maybe this is not affordable....
If you want, I can look thru my stuff, and see if I have the right crank. Something tells me that I have one.
Therr are 13 on ebay right now. Do not buy or accept any crank that has even the slightest rust on the journals, or permanent roller bearing marks on the journals. These are hardened cranks, and cannot be repaired like a car crank. There are no oversize bearings available, and if you tried to turn one, you would kill the hardness temper.
PM me if you want me to look. It would be a 434771 92 up crank. I would let it go reasonable. I have seen prices up toward 1000 on EBAY, but would never go that high.
furyimp
Thanks for your offer but I'm in New Zealand and the shipping on something as weighty as a crank would be a killer. I will try the local guys for a used crank as an option but my pal reused his stem and lower unit so I would need to find a later version to complete the project. The difficulties are starting to overwhelm the economics. Thank you for your assistance.
daselbee
New Zealand....well.....that sort of changes things a bit. I have read many posts from guys from AUS and NZ, and it seems there is a common thread. The cost of parts and for that matter, the cost of a whole engine is extremely high. So much so that you guys want to keep your gear running any way you can. (Good ol' Durban comes to mind.)
I hope that is accurate. That's what I get from some of the posts....
Anyway....the 88 driveshaft is a one piece deal, with an o-ring at the top that seals the crank to driveshaft joint. No o-ring, and you rust the splines and then the LU is stuck and cannot be removed.
The botttom end of the crank on the 88 is plain splined opening, nothing special.
The 92 DS splines are the same in size, count etc. as the 88, but the length is different, and the o-ring does not exist on the end of the driveshaft. The o-ring is captive in the end of the crankshaft, which also has a hardened chrome sleeve pressed over the end.
To keep your gear running, considering your location, I would look very carefully at the tops of the driveshafts for both years.
See if you can figure out a way to seal that DS to CS joint. If you put the 88 driveshaft in the 92 crank end, the o-ring would lie on splines, and never seal. Also, (this is iffy, from way back in my memory), the 88 DS is just a touch longer, and when assembled, LU, midsection, and powerhead, the top of the DS will bottom out in the crank putting "squeeze" pressure on the whole assy. That can easily be eliminated by shaving off the top of the 88 DS about 1/4" or so.
You can do this with careful measuring, some innovative ideas to rework the top of the 88 DS, etc.
On the 92 CS...where the bearing is seized at the top, you can definitely turn that down and sleeve it up to nominal size. The bearing is available separately from aftermarket suppliers (not available from Evinrude). You can get this bearing from promarineusa.com. Press the old seized one out, and press the new one in. I really don't think there is a whole lot of stress on the upper bearing surfaces, at least not like the center bearings and the rod bearings. I bet sleeving that top roller surface would work just fine, and keep you going even tho it is not "corrrect" as far as repairs go. I just had a thought...your '88 upper crank cap with bearing will also probably work.
Good luck.....maybe Fazt will jump in here and comment....all this is kinda speculative on my part. He may know something that will add more light to the question.
Faztbullet
You can run a 1979-1991 V-6 driveshaft on a 1988 crank. Drive shaft measured from mounting flange to top of d.s 21 3/4 inches. On 1992 and up will measure 22 1/8 . To make this work you will need to do the following: swap cranks and use the 88 lower seal carrier on the 92 block, tear down lower unit and replace 1 piece drive shaft with new style 2 piece. If you look at cranks the 88 extends out of carrier and 92 is almost flush.The parts you will need are 335722(lower) and 5000614(shaft)
furyimp
Maybe there is hope after all. I'll check with my pal for details of his dshaft. His engine came from a plant in asia somewhere so who knows how it was built but he sure will as he broke it a few times. I saw the LU lying in his boat and it did not look any different to mine. Does a 2 piece shaft have a giveaway appearance?
Back to my original question for a moment, Will my carbs and intake mate with his block and will they feed it satisfactorily?
furyimp
Just had a thought. If I'm fitting an 86 crank to a 92 block and refitting an 86 LU won't the two ( c/shaft and DS) be a match or is the 92 block a tad shorter on the lower face?
Faztbullet
If you use your original unit you will only need to change seal carrier, The only difference between a 200 and 225 is the carbs and to runs your carbs you need to rejet to 89 model 200 spec's. You will end up with a 200 not a 225...
furyimp
I have asked my pal about his driveshaft and he is 100% certain it is a 1 piece deal so his engine must be a '91. He was a little vague about the year in the first place. Sometimes he is a bit vague.
So now I have an '86 225 with damaged bore and (I hope) usable crank and a 91 225 with damaged crank and good block/pistons. The confusion about the year has muddied the water a bit so can we back the truck up and start again. What is going to fit what? Will I have to rejet my 225 (small bore block) carbs? Sorry about the bum steer I gave you at the start. Thanks
Faztbullet
1st lets see a picture of the 90's model crankshaft where driveshaft enters, 2nd yes will need to rejet carbs and it will only be a 200hp.
