johnson v4
Lee Hough
i have a 1980's johnson v4 and i just want to know what setting to set the rev counter to, i thought it would be 4 but someone told me its not how many cylinders it has its to do with the fly wheel please help
Dhadley
Re: johnson v4
Welcome aboard the board.<br /><br />I'll second the six. It has to do with the stator. Thats what the tach reads.<br /><br />Good luck!
Lee Hough
Re: johnson v4
thank guys for your help i will go and try it.<br />Lee
Bobby D.
Re: johnson v4
Hi I, I also have a eighties v4 and I don't understand the term rev counter and what does the "6" mean. Thanks
ab-normal
Re: johnson v4
I am assuming it is the output from the stator to the tachometer. If the stator puts out 6 pulses for each revolution of the crankshaft, then the tachometer has to devide by six to get the correct RPM reading.
walleyehed
Re: johnson v4
12 pole stator on the V4's, 6 pulse. 10 pole stator, 5 pulse and so on.....
