johnson v4 gearcase
Johnson110
I wanted to know if anyone knows how many tubes of marine gear oil are needed to fill my gearcase after i drain it for winterizing, should two tubes do it? :confused:
R.Johnson
Re: johnson v4 gearcase
The dealer should have a chart that will tell how much you need. I am not in the shop right now to look at the chart, but it will depend on what V-4.
DHPMARINE
More info is needed,but the basic is,pump into the bottom until it comes out the top.<br /><br />The tube(s) work great if you have a small HP motor,and need only a few ounces.<br /><br />For my do-it -yourself customers,I suggest they buy the gallon oil jug,and the proper pump.Now they can hand pump the oil in,and not squeeze against gravity,loosing alot.Probably about $40.00 ?? (total purchase )<br /><br />Next year they only buy a quart or two of gearlube,to top up the gallon bottle.<br /><br />DHP
Johnson110
Thanks for the replys, it is a 1986 110 hp v4, i was not sure of how many of those tubes to buy!
DHPMARINE
Probably about 22 - 24 ounces but I'm not sure.<br /><br />DHP
mauiboy
it take 3 1/2 tubes I have the same motor.
Johnson110
Mauilboy, Are you sure, i put 2 1/2 tubes in fluid started coming out of top hole.
R.Johnson
That oil is sold in tubes, and plastic bottles. If you sqeezed it in the bottom, and it came out the top, it's full.
papasmurf
According to my Bombardier P&A book, the gearcase capacity for a 1986 110HP is 26 ozs.
mauiboy
I am sure the gear case must not have been drained all the way.<br />I did mine in aug. and I drained it let it drain for a 24 hr. then refilled it and it took 3 1/2.
Marc J.
What SoLittle said! You'll find it at Wal-Mart. The tubes sould like too much work. Replace the o-rings while you're at it.
