Hi!
My V4 120hp looper -89 overheats at starboard side at 4000rpm and above, with the alarm squealing (high temp measured with gun, so the alarm sensor is correct).
- The water pressure at idle is ~15psi, above 4200rpms it raises to 30psi (max what the gauge can show).
- Tried with the old and new thermostat housings (known as the black variant), same story..
- No issues at idle, then the temp is perfect on both sides (~160F).
- Running the engine with just the thermostat plastic housing on stbd side only (no thermostat inside) works, no alarm goes off, but the pressure does not as easily max out the gauge (quite understandable when no thermostat is inside).
- Started the engine without the t-stat cover and the water shoot out at idle about 3 feet. There was water coming through the line to the t-stat cover as well.
What could be the cause? The port side seems perfectly fine.
How important is the condition of the grommet that seal against the thermostat housing in the cylinder head, if it is a bit leaky connection, could it create such issues..?
Many thanks for any ideas!
//Steve the Swede
//Steve the Swede
