Johnson V140 Starter motor
dirkstorm
I have a 1988 Johnson V140. Went to start it and the starter motor only went part way up and never engaged the flywheel. New battery, full 12 volts. Any suggestions?
AEROCOOK
Master Chief Petty Officer
Poor / dirty electrical contacts. The battery cables need to be shiny clean on both ends. To test my theory, use a set of jumper cables directly onto the starter from a known good battery and see if there's improvement.
jakedaawg
Yep. Clean and tighten with a wrench all cables. Load test battery. Even new ones can be bad. If that fails disassemble starter and check brushes and commutator. Basically what these guys said
How fast was the starter motor turning? If it was cranking sufficiently fast but the bendix just refused to go up it may be as simple as lubing the bendix (the factory manual calls for a light grease on the bendix as part of routine maintenance - just don't overdo it).
If that's not the issue then it could definitely be a poor connection, a bad cable, or a bad solenoid. To find out where the problem is you measure the voltage across each part of the system while someone turns the ignition switch for you. (you measure voltage from the battery + terminal to the hot terminal on the solenoid; measure voltage across the solenoid; measure voltage from the solenoid to the starter motor; and measure voltage from engine block back to the - term on the battery). I don't have my manual in front of me to look up the acceptable values, but if any one of those gives a high reading you've found the culprit.
