Johnson two stroke 4hp seahorse J4RERE....need help
Coquinick
I have a question about assembling the the lower unit/ mid section to the power head. In the mid section coming down from the power head are three lines. One is the forward/neutral shaft, the other is a short shiny tube and last is a copper tube that is long and reaches to the lower unit itself. Does the copper line sit inside the plastic impeller housing?
One more question, this deals with the gear assembly in the lower unit. In between the ring gear and the pinion gear there is a thrust bearing and washer that butts up between the ring gear and gear housing. The washer is flat on one side and has a small taper on the other. Does this washer face the flat side to the thrust bearing or the tapered side? Thanks for any help.
Bonaventure
The Copper Tube is for the cooling water to go from the water pump to the engine,, yes it does fit into the plastic impeller housing. There should be a rubber bushing to hold it in place both at that location and at the top of the leg.
F_R
Honorary Supreme Mariner
Don't know the answer to the taper question, but is there any indication which side the rollers have been rolling against? They generally leave a burnished appearance where they were.
The " small taper " AKA chamfer normally goes towards the housing on these.------But post a picture and as stated the wear pattern / marking will tell you which way it goes.
oldboat1
gearcase: http://www.iboats.com/Gearcase/dm/cart_id.035006330--session_id.344950468--view_id.1535978
exhaust housing: http://www.iboats.com/Midsection/dm/cart_id.035006330--session_id.344950468--view_id.1535989
Last worked on one about 10 years ago, but the shiny rod (bigger one) is the driveshaft (22 -- gearcase diagram), and should be inserted and contained in the lower unit -- brought up to the powerhead when replacing the lower unit. The copper tube (38 -- exhaust housing) should be coming down from its location in the the powerhead, and fits in the grommet as indicated (18-- gearcase).
I'm not sure what issues you were trying to correct, but the diagram should show basic relationships and orientation of gearcase parts. Use regular gearcase oil intended for mechanical lower units, available from a number of retailers. Replace the gaskets used for the drain and fill screws. I recommend a pump assembly to assist with refilling the gearcase -- probably found in the same location as the lower unit oil.
