Johnson tracker gt 150 stalling.
galaxyzander
So I have a johnson tracker gt 150 2 stroke and its causing me problems. Just bought it and was told it will go across the lake just fine but when u shut it off its hard starting.
Well I took it out and it was hard to keep started but not to bad. I cruised across the lake and it was a dream. Then I went to start it again and it was a little hard to keep starting so I instantly put it into gear after starting it and gave it some gas and it went fine for a min. Then while I was going it started to putter and eventually died on me and wouldn't stay started for more than a second. So I popped the hood and let it set with it trimmed up for about an hour and finally got it started and quickly put it into forward and was able to put my way back to the dock. As soon as I got to the dock I tried to put it in reverse to slow me down and it died as soon as I reached neutral. Before I could get to reverse. Any thought. There's no fuel filter on it currently so that's not the issue.
Honorary Supreme Mariner
You start with a compression test on that motor.------Just report the numbers you get.
fhhuber
Pull off the engine cover.
Engine in normal planing trim
Engine not running, so it does not have to be in the water.
Pump up the primer bulb HARD and look at the fuel pump and hoses inside the cowling. You are looking for it leaking. Pulling air through a small leak will drive you nuts.
Still the OEM "VRO" fuel pump? Look up the test to check that its pumping the correct amount of oil.
galaxyzander
Ok will do. They made it were the gas gets mixed in the tank instead of using the VRO to mix it because they thought that was the issue. Im going to be changing it back. Would a dirty carb be causing this problem.
fhhuber
Actually... you are safer mixing the gas and oil in the tank instead of trusting that old VRO.
If the VRO fails to deliver oil the engine will be ruined before the alarm goes off.
galaxyzander
It almost sounds like it's backing a little bit. I know the engine is jerking a little bit while running on the hose.i did just hit it with sea foam and carb cleaner. Im gonna look for a small air leak right now
galaxyzander
So did a test out on the water and it had a hard time starting at first. Was even backfiring a couple times. But once I got it started and it died on me a couple times. Then it started and ran perfectly. Kept starting up and staying idle without dying. Any thoughts on why it was so hard to start at first. I know the whole choke thing. But not sure how long I'm supposed to have the key pushed in for choke before starting it.
