Johnson TRACKER 25 fuel issues
Fairmontmike1978
Ok, so i am pretty knowlegable when it comes to repairing boats. Ive never really had a issue i couldnt solve.... but this has me stumped! As soon as the butterfly opens, the motor bogs and wants to die. If i cover up half of the carb opening, it will run full throttle without a issue....part fish dosent show a air box for this model. I have put fresh plugs in it, i have had the carb off multiple times looking for something i missed, new gaskets, have soaked the carb, made sure all is clean and air and carb cleaner goes through every passage....and if it runs good full throttle covering up the throat, thats telling me its getting enough fuel and i am ot losing spark. Compression is 120/122....any thoughts or solutions? Thanks in advance!!!
kbait
Running better while choked points to partially clogged main jet in carb, or air leak in carb or intake manifold. Spray some carb cleaner around suspected areas when it’s bogging to discover air leak.. it will run better when carb cleaner is drawn through leak.
Good luck!
