Re: Johnson throttle tilt and trim switch
Ken....find the connector for the wire from the handle and pull it apart. With an ohm meter, do some make break readings from the red wire to the green and blue wire. If the switch is bad, this should show you. To get to the switch, the control handle needs to come off. One screw (allen wrench type) holds the handle on. You will have to get to it from the back of the control box. After the handle is off, getting to the swtich is easy.
