johnson td 20 46-49 5 hp how to remove prop shaft?
nick4203
Re: johnson td 20 46-49 5 hp how to remove prop shaft?
now all these Q's are regarding the area between the power head and lower unit the main shaft
Here are the 2 little holes in the main shaft going to the lower unit i get water and exhaust sputtering out of there is this normal i believe it may be but am unsure?
then i got a grease leak on top of the lower unit under the adjustment bolt on the left in the pic
the grease leaks out ever so slightly hear between lower unit and shaft ?is there a seal or something right there?
nick4203
bump
nick4203
anyone?
nick4203
is any one looking?
