Johnson swap with Evinrude
Tarheel316
I have a 2000 Johnson 115 that I'm replacing with a 1997 Evinrude 90. The Evinrude is coming with the controls and I was told that I had to switch them out but I've read that the controls for the Johnson will work with the Evinrude. Is this right and if so does that mean all I have to do is take one off and put the other on. Also the Evinrude is premix and the Johnson is VRO so do I just unhook the oil tank. I would appeciate any feedback. Thanks
derek4325
Controls for johnson/ evinrude are interchangeable as long as they are from the same era. In your case the controls may work but keep in mind that the wiring harnesses are likely to be different. So I would say you are better off with the controls that come with the evinrude. As for the VRO yes you will need to completely isolate the tank from your motor and gas tank and pre mix the gas in the gas tank on your boat.
flyingscott
If the VRO is in good working order I would see if it would transfer to the other motor and keep it.
boobie
IMHO I'd still keep using the premix. I just don't trust VRO's and I've been working with them since they first came out.
