johnson/susuki 4x system check gauges
geometric
I think my tachometer died. I have a 115 hp. Johnzuki (2004, 4x Johnson made by Suzuki). It was working fine then it started sending a over heat signal when the engine wasn't hot. That stopped, now the needle is stuck on 4,500 RPMs even with the engine not running. I appears to be dead, although the warning lights flash briefly when the engine start switch is turned to on. The engine starts & runs fine (in test tank).
My question is, what are my options in regard to gauges? Obviously, if I install a new "system check" tach. programed for the engine, it should return to it's former operating status, assuming that was the problem in the first place. I am thinking of upgrading the instrument panel to include a oil pressure & a temperature gauge. Would that be compatible with a OMC system check tachometer? I've never been a fan of idiot lights. The instrument panel lives in a wheel house so it is relatively protected from the elements. I don't think it makes any difference but the boat is a Novi (lobster boat/ down East style hull) used mostly offshore. That's why I like to keep close watch on my engines vital signs. I am pretty good at following directions & wiring diagrams but an electrician, I am not!
