johnson super sea horse 35
crownline60
i have inherited a boat, has a johnson super sea horse 35 hp. the boat has not been in the water for 10 years i have changed fuel lines and cleaned it up the plugs are very clean. it will sputter but not idle. on the carb there is 2 adjustments for rich lean, 1 is a screw/turn pin, the other is attached to a lever. i'm not sure where to start. i am running 32:1, and i am not sure what the plug gap is suppose to be.
please advise.
1946Zephyr
Re: johnson super sea horse 35
24:1 on the fuel mix. 32:1 won't hurt it, but 24:1 is recemended. Top screw (low speed) sets at 1 1/2 turns out from lightly seated and bottom screw (high speed) sets at 3/4 turn out.
You will want to replace the water pump impeller and thermostat on that motor, as well. Check the lower unit oil for water intrusion.
crownline60
thank you for your time, i will give her a shot.
