Johnson starting woes
Rooky
Hi all,<br /><br />We have a 1986 Johnson outboard 90hp v4, was running fine and shut motor off for a minute. All of a sudden the motor will not turn over. Can hear the starter turn, took cover off and can see it turn but will not pop up to engage flywheel. Does this sound like a solenoid maybe? Any suggestions would be appreciated. Thanks!
alcan
Re: Johnson starting woes
Hi Rookie<br />Clean and greese/oil the shaft the gear slides up and down on. Your selenoid is fine.
Rooky
Alcan,<br /><br />Thanks for super fast response. I am pretty new to outboards, so please excuse my ignorance, but am i supposed to be able to move the starter gear/spline up and down? The gear on the starter is sitting about two inches below the flywheel and i cannot move it up to get to the shaft to clean it. Thanks again, have a great day!
Rooky
Alcan,<br /><br />I was looking at the motor this morning, i was kind of wondering if maybe the gear on the starter had slipped. There is an adjustment nut above the gear. Is the gear supposed to be aligned with the flywheel at all times? If so, do these slip out of adjustment periodically or do you think something broke? Thanks a million!
bhalsdorf
You don't need to adjust anything. The nut is there to hold everything together. When the motor turns the gear is spun up a spiral spline to engage the flywheel. Just move the gear up and down by turning it by hand and spray the spline with WD40. It will work fine after that. The spline looks like a very corse thread.
Rooky
Thank you guys so much. Did what you said and the world is all better now. Wish I could buy you guy's a drink!!!!!! You Rock!!!!!!!<br /><br />Thank you Thank you Thank you!!!!!!!!!!
