Howdy.. I have a 2001 Johnson 135 outboard with a starter motor that doesn't kick up and engage the flywheel. Problem occurred suddenly as opposed to gradually. <br />Batteries are both good (12.6 volts). Bendix spins, but not fast enough to lift the upper rotor. No corrosion evident anywhere. <br />When trying to start, I put a voltmeter on the starter. I saw about 8.5 volts. I wasn't sure how to determine if I might be losing the voltage in the solenoid, but I am obviously losing voltage somewhere. (I had the starter bench tested and it is good.) Out of ideas. Any thoughts? Thanks in advance. Tim
