johnson seahorse model 647340 TD20
nophakao
:confused:I have just acquired a Johnson seahorse model 647340 TD-20. this is my very first motor and i am quite excited about getting it running again. I took the engine apart and now i need ot find the gaskets for the motor and the problem is i have a broken connecting rod. I have looked on ebay and they don't have the same year as what i have, this does anyone have an extra!;) Thank you for your help!:)
BigB9000
Re: help!
Re: help!
....problem is i have a broken piston rod.
Pssshh!
Get yourself a different motor and Ebay the parts.
If it blew a rod, I'm sure you have cylinder, crank, piston, case damage, and probably chunks missing from the intake manifold.
You'll probably need a new powerhead.
pics of the engine?
nophakao
Re: help!
Re: help!
thanks for the quick response, i am on a tight budget and the engine still looks real good just the rod is busted no scratches or pieces left in gngine d you know where i can just get replacements?
BigB9000
Re: help!
Re: help!
use your digital camera/cell phone and take pics.
I might be able to help you out....
nophakao
Re: help!
Re: help!
will have the pics for you by tomorrow thank you!
nophakao
Re: help!
Re: help!
sorry that is the connecting rod that is broken, just need a new one!
Mas
Re: help!
Re: help!
Try eBay...I just saw a lot of TN stuff there. You might get lucky.
MAS
nophakao
Re: help!
Re: help!
sorry i cant download the picture says the file is to big but just a new conecting rod is what i need and thank you all for your suggestions.
nophakao
Re: help!
Re: help!
the connecting rod on a seahorse model 647340 td 20 are they the same length as what would fit JOHNSON 1956 56 FDE 10 15 HP CONNECTING RODS?
F_R
Re: help!
Re: help!
Not even in your wildest dreams!
EDIT:
Go to www.aomci.org and place a free want ad on their Webvertize Classified Ads page. I'll bet you'll find one there.
wbeaton
Re: help!
Re: help!
According to your serial number your motor was built in 1948. The connecting rod is the same for all the LT/AT/DT 4.2 hp Johnson's 1937-40 and the TD/TN 5 hp Johnson's 1946-53. The original part number is 42-75.
