Johnson Seahorse Fuel Line Connector
rTagster
I am looking for the fuel line connector that is on the motor itself, i need the male connector that is permanently on the motor, i need just the male single fuel line connector. I have not been able to find this part so far on the internet. I have a Johnson Seahorse CD-10 5.5hp that i converted to a fuel pump from the pressurized tank system.
Does anybody know where i can get one of these or at least have the OMC part number to help my searching? Thanks
I provided a picture of the connector i need, it is the one on the left. Thanks again.
F_R
Honorary Supreme Mariner
Re: Johnson Seahorse Fuel Line Connector
The number you are looking for is 376154, which has changed to 393334. 376154 was used on a bazillion motors and there should be lots of used ones around. The appearance has changed several times, but any will work. The latest one has a check valve to prevent dribbling when you unplug the hose. That check valve makes it $$$$. I'd rather have the dribble.
rTagster
Ok sweet thanks, so i found the connector "OMC 303600" which looks similar, is there any real difference? I'm going to go with what you told me but was just wondering why the difference.
