JOHNSON SEAHORSE 3hp
jolozo
Hello everyone!!I have an old johnson seahorse that I would like some info on. If anyone can help me it would be greatly appreciated. The motor is a 3hp I assume with a model# jw-15 and a serial#1894546. What I would like to know is what year is it, and if I can still get rebuild gasket kits and manual for it. thank you jolozo
JB
Re: JOHNSON SEAHORSE 3hp
It's a 1959, Jolozo.
jolozo
THANK YOU JB FOR THE QUICK REPLY!!!!! THAT IS A STARTING POINT. IS THERE ANYONE WHO CAN TELL ME WHERE TO GET A MANUAL AND REBUILD GASKET KIT FOR THE CARB????? THANX JOLOZO
steelespike
jolozo, You can get after market ser. manuals right here on iboats at the bottom of the page.<br /> You can get a carb kit at NAPA auto parts,<br />also Impellers,points,condensers, coils and<br />manuals.<br /> If you want reprint factory manuals try<br />www.kencook.com be prepared to dig deep.<br /> specs:3 hp @ 4,000 rpm,5.28 cu. in.J4C plug @ .030,points.020.Stick with 24:1 fuel mix.<br />with TCW3 rated oil.
jolozo
tHANK YOU VERY MUCH FOR ALL OF YOUR HELP SPIKE. THE INFORMATION IS GREATLY APPRECIATED. ALSO THANX AGAIN JB FOR YOUR HELP ALSO.
