Re: jOHNSON SEAHOARSE 55 NEED BIT MORE SPEED
Im just a noob but, my idea is a 14.5 ft boat is pretty small for a 55hp ,which weighs quit a lot.<br />Maybe check the realtion to the antivent plate and the boat? should be about 1-2 inches if more than 2 inches it can slow teh boat down and spray alot of water. secondly sinc ehte engine is big on a small boat, the rear of the boat must be deeply in the water causing the head to be high. So maybe change the pin of the engine so that it is slightly less than 90 degrees. i.e so that the prop is slightly closer to the transom of the boat. when running, it will make planing faster because the head will go lower quickly, creating less friction on the boat's body. and it should also make more use of the deep V.
and again if this is nto the case, im jus a noob...tryin to help
