Johnson Sea Horse ID Help
Status
Not open for further replies.
sebefus
Cleaned out a garage last week and was given an old Johnson Sea Horse model HD25, Seriel Number 568404. Can someone ID the year, oil/fuel ratio and recommend a repair manual. The engine seems to have great compression and is in very good shape.
Thanks in advance.
Scott
seahorse5
Re: Johnson Sea Horse ID Help
Thanks in advance.
Scott
If you can read the decal on the front of the motor it says to mix 1/2 pint of oil per gallon of gas. That is 16:1, plus that old a motor probably has a lot of internal wear so the extra rich oil mix will help "fill in the spaces."
Set the low speed needle on the front of the motor to about 1/2 to 5/8 of a turn open and the high speed knob to about 1- 1 1/2 turns.
samo_ott
I have 3 of those engines and they are finicky and parts are hard to come by. But if you get it going, let us know how it went :)
sebefus
Thank you all for your responses.
19katie95
I also need help identifying a Johnson Sea Horse. After my dad passed away I inherited it. The outside cowl has 3 Hp decals. The decal on the front that gives the manufacturing location and the oil and gas ratio mix says 3 hp OBC at 4000 rpm. Stamped on the side of the engine model #HD 20 Serial # 451154. Looking up this model # on the internet states it is an early 1940's series 2.5 hp. Can anyone clear this up?
samo_ott
You should start another thread on this topic, but you're new... So next time :)
The HD-20 was made from '41-'45. Serial # 451154 was made in 1942. It is a 2.5 hp engine. The decals must have been changed. The model # tells all.
ezeke
The motor was called a "Seahorse '3' with recoil" and your serial number is from 1941.
samo_ott
According to my book the serial numbers went like this:
1941 - 397901-439206
1942 - 439207-460782
How does your book differ?
ezeke
1942 is correct.:redface:
Johnson1941 HD-20 Sea Horse "3" w/Recoil 397,901-439,206 2.50HP
Johnson 1942 HD-20 Sea Horse "3" w/Recoil 439,207-460,782 2.50HP
Johnson 1945 HD-20 Sea Horse "3" w/Recoil 460,783-491,736 2.50HP
Johnson 1946 HD-25 Sea Horse "3" 491,737-538,800 2.50HP
Johnson 1947 HD-25 Sea Horse "3" 538,801-614,514 2.50HP
Johnson 1948 HD-25 Sea Horse "3" 614,515-698,874 2.50HP
Johnson 1949 HD-25 Sea Horse "3" 698,875-787,023 2.50HP
Johnson 1950 HD-25 Sea Horse "3" 787,024-869,939 2.50HP
Johnson 1951 HD-26 Sea Horse "3" 869,940-920,749 2.50HP
badsign
I have a 35 hp johnson seahorse 1983
Does the Seahorse mean anything?
or is it just a name?
salt or fresh?
minntac
I just became owner of HD25, s/n 501901. Can someone tell me what year it was made and if there is a manual available somewhere? Thanks
GA_Boater
If you start your own thread someone may answer your question.
This thread is almost 10 years old.
Closed.
Status
