Re: johnson sea horse 60 electric
As I remember it, on that model, there is no resistor wire leading to the (+) side of the ignition coil, and 12 volts would be applied directly to it.<br /><br />That connection should be in force only when the engine is running, being started. If that 12 volt supply is left connected for any length of time without the engine running, problems will develop, the exact nature of the problem would need to be trouble shot.<br /><br />Check the points to see it they have been burnt.
