I recently bought a sailboat which came with a 1989 Johnson sailmaster 9.9 hp outboard. The motor runs fine at low speed (idle) and at high speed, but stalls when I try to run it at an intermediate speed, about where the start engine mark is on the throttle. I had the outboard serviced and replaced the gas can, fuel line and fuel filter before I started it. I took the outboard back for a second service when I had these problems and they adjusted the carburetor. However, the problem persists. At low speed I don't have enough speed on the boat to have steerage, but high speed is too fast to manoeuver in the marina to get in and out of my slip. The motor has a knob on the end of the throttle handle which I understand has something to do with setting trolling speed but turning it doesn't solve my problem. Has anybody else had a similar problem?
