Johnson running issues
Metalworx
Hello, I have an 80's model 8hp johnson engine. It will crank and idle great. I put it in forward and it will run great for a while then will cut out when I'm running full throttle. If anyone has any opinions on how I can go about fixing this I would greatly appreciate it.
Bosunsmate
Might be the fuel pump.Try manually acting as the fuel pump by squeezing the primer bulb as you rocket along, if that fixes it then you need a fuel pump repair kit
Bosunsmate
If its not that you will need to take a spark checker out with you on the water, or timing light
Metalworx
Thanks for the reply.It has a new fuel pump on the motor, if it is the spark would changing coils and power pack fix the issue? I kinda gave up on the motor and haven't ran it in about 2 years in trying to get it going right now and want to go about it the right way? I did replace the fuel pump,carb gaskets and plugs when I started working on it at first tho.
mfkadz
Depending on how you left it you may need to rebuild the carb again. Yes, try to pump the bulb when it's starting to fail. If that does it there's still a possibility of an issue with the pump or the plumbing. Maybe a leak. If you have a vent on your tank make sure it's open. Or try running it with the cap loose or off.
mike
