Johnson qd 20 need to get up and running
F_R
Honorary Supreme Mariner
Re: Johnson qd 20 need to get up and running
?Huh? Did you disconnect the shift rod at the connector behind the oval plate on the side of the midsection? That, plus the bolts is the only thing keeping it from coming down. There will be a tad of resistance as the water tube pulls out of the grommet, but it is way out by the time you have it down 3"
bbenkaz
I firgured it out it was the shift rod connector! Good thing I decieded to take it all the way apart it really needs a good cleaning. I did have a couple of unfortunate events. The piece that the shift rod screws through broke I was caked in crud I tried to take it off so I could clean and the retaining screw head broke off. When I tried to drill it the thing snapped The top arrow shows where it goes.
The second thing the retainer that the drive shaft comes up through got bent when I was trying to slide the lower unit back in the first time:% That is the second arrow as I am sure you know. Does anyone know the part numbers of the jewel or even if I can get them?
Thanks
bbenkaz
Will a 62' 10HP parts be interchangable?
F_R
The inner lever is 377188; screw for it is 303714; tab lock washer is 303715; the baffle plate is 305297; powerhead gasket is 308385. All are available according to www.ishopmarine. If you can straigten the baffle plate to where the crankshaft's carbon seal parts don't contact it, it should be OK. Hang onto your upper teeth when you see the price for the lever!
F_R
Yes, '62 parts are the same
bbenkaz
sweet thanks fr That inner lever is a little pricey I wish they showed pictures of those part numbers you gave. Thanks a lot
F_R
Probably easier than writing it all down.
frankr_photos
F_R
Trying again,
bbenkaz
Thanks FR I actually meant on their website at ishopmarine just so that I could be sure of what I was looking at was the same thing. I appreciate you posting up the drawing.
Thanks a lot 8)
bbenkaz
Should this look like this?
It looks awfull sooty in there how do I clean this out without getting a bunch of crap in the cylinders?
Also Why are those holes in the cylinder walls doesn't the water come up in that chamber it is not closed off from the other water chamber? Sorry for my ignorance.
F_R
Don't worry about the carbon. That is the exhaust passages and all manner of smoke and crud goes through there. It won't affect the engine operation at all. It's just a nasty place.
Say what? Are you talking about those 8 big holes that you can see the piston through? Those are the exhaust ports. The pistons open and close them as it travels up and down in the cylinder, serving as valves. The only dumb question is the one that is not asked. You might be interested in reading up on how a two cycle engine works. OR am I not understanding which holes you are talking about?
bbenkaz
I see said the blind man. I have never taken a 2 stroke motor apart before or an outboard motor. Well I guess the follow up question would be where does the water from the impeller go it looked to me like it travled up the lower unit and into the motor for cooling is that not correct if so which passage does it take. Sorry I really am and that for all your help guys.
F_R
bbenkaz
Awesome, again I apologize for my igronace.
I there anything I can do to clean this out just to make sure it is clean and clear while I have the motor off?
Thanks
bbenkaz
gaskets?
gaskets?
I found some of the gaskets I need but I am trouble finding the others.
Where can I find:
Head Gasket original# 306174
Powerhead gasket original #308385
Exhaust cover gasket original # 306171
bbenkaz
And probably lower unit seals also d:)
thanks
Sierra gave me numbers for the rest of what I need
bbenkaz
Well..................
Thanks to everyone here for all of thier help. I took the head off of the motor yesterday and the gasket was of course disenegrated. It appears that one of the cylinder liners has a fracture so appearantly I will not be having a motor to repair. If anyone needs any qd-20 parts let me know I may part it out on ebay also. I guess I could maybe find a powerhead that is good if anyone knows of any?
Thanks again for all your help
Ben
bbenkaz
I am having second thoughts about this cracked cly. I figured it could not hurt at this point so I took the pistons out so I could inspect the cyl a little better. How do you tell the difference between a crack and a scoring mark?
This is the best picture I could get it is kinda tough to see without perfect light. Does that look cracked or scored?
