blpierce76
Thread starter- Joined
- Feb 28, 2014
- 23
Hello everyone,
I recently got a hold of a Johnson QD-18 to use as a trolling motor for my boat. I found this site while looking for parts. So, I got the motor unstuck, replaced the spark plugs and adjusted the points. I got it to fire up, but while its idling it bumps hard enough to jerk the motor to the side and then it revs up a bit then slows back down.
I'm thinking it an issue with either the fuel system or the ignition. I do have a carb kit, new coils on the way (the plastic is cracked), and a water pump kit on the way from iboats - Thanks! I am hoping these fix the problem, but was wondering if anyone knew specifically what would cause this.
Hoping to have this beauty running soon. Thanks!
