johnson outboard throttle linkage locked up
anglerfishingbuddy
Hello all, I am new here and to the DIY boat repairs, I replaced my shift cable and throttle cable on my 1999 Johnson 90hp I put it all back together and the shift cable and linkage is spot on when in neutral i can turn the key and it will crank, but when I hook up the throttle cable it will not move it was not like that prior to cable change. is there a safety or when i removed the throttle cable it went forward and engaged something to lock the throttle from moving forward and backwards? With the cable unhooked the cable moves freely but the linkage on the motor is in the locked forward position by about 3/4 inch i need to unlock it and move it backwards to get it to reach the cable.
thank you for any advice or help to get me back on the waterT
