masterangler
- Sep 2, 2008
- 14
my motor is about a 1972 40hp super sea horse. The motor sat for 6 years outside, but just recently i got it all fixed up, i got new points, condensers, coils, plug wires/plugs, and the carburator got cleaned out along with the float adjusted. From what i remember it years ago when it ran it was alot faster than it is now. Anyways, i took it out 4 times since i got it back from being fixed, as i said it didnt seem like it ran as fast as it did 6 yrs ago. I had it out a couple days ago and it was running worse than it has been, the longer i ran it the harder it got to start and when running wide open throttle it would keep on spitting or seemed as if it was missing. Finally the motor died and it wouldnt start again. I got it home and took the plugs out they were pretty dirty and checked the spark and there was spark. I guess i need someone elses opinion here that knows more than me on what i should do to get it started now. And if theres anything i can do to make it faster when i get it going. A guy told me the motor should smoke a bit because its a 2 cycle motor, the motor never smoked when i had it. And how much oil should i mix with 6 gallons of gas? Thank you for your help
