davio47
Thread starter- Joined
- Aug 29, 2009
- 31
I have a Johnson 15 hp model 15R75C and I experienced the recoil failing to retract. I removed the recoil assembly and restrung with new rope and re-tensioned the recoil. Pulled it several times and it seems that it is jumping out of the spring. Is there a way to make this assembly more robust. It seems a little sensitive. Please let me know if you have any ideas out there to make it more robust. Do I need to replace the recoil spool? It seems to be OK, or is it not capturing the spring as it should? Thanks, I look forward to hearing from you all.
