Johnson Ocean Runner peaks at 5000 RPM
SUBWAYJO
I have a pair of 1994 200 hp Johnson Ocean Runners, one peaks out at 5000 rpm and the other at 6000, I just changed all the plugs. any suggestions. Joe
ob
Re: Johnson Ocean Runner peaks at 5000 RPM
Assuming these engines are propped the smae and driving the same boat as a pair I would perform a spark test on the engine and insure you're getting fire to all of the cylinders.If that checks out ,a compression test would be next.All good there?May be fouled carburetors or a fuel delivery issue.Throttle linkage allowing for full opening of carb flaps?Did all of the sparkplugs look consistent in color and condition on the engine in question?
Captn Dave
I had a similiar problem once and found a bad plug. The plugs were fairly new too.
Orlando Len
something else to keep in mind. I had a problem with one engine not spinning up as well as the other.( twin Honda 130) I ran it with the stb throttle lever about an inch further down then port lever to make the tachometers equal. Turns out I had a bad tachometer. Swapping the sensor leads moved the symptom to the port side.
