Johnson Ocean Pro's Leaking Oil
Twoc
I've got a pair of 150's that leak oil out the front of the carbs when they sit up for a day or so. When I crank them, they smoke horribly. I've read several posts but none address the leaking oil out the front of the carbs and then down the engine housing. Its like the VRO pumps oil all the time. Any suggestions?<br /><br />Thank you for the help.
rodbolt
Re: Johnson Ocean Pro's Leaking Oil
hello<br /> check the vents on the oil tank caps. if they dont vent it can pressurize the oil tank and caues this. also if the tanks are mounted higher than the engine it can happen. my 120 will fill the carbs full of oil if I leave the engine tilted with the fuel valves off. it is a good excuse to go run it once a week:).<br /> good luck and keep posting
seahorse5
the all black oil caps only have a 1 way vent for vacuum. Pressure can build up in them. The quick fix is to use a straightened paper clip and push it into the center hole on the inside of the cap. You have to push kinda hard and you will feel it go thru the hollow rubber tip. Now your cap can vent both ways and not build up pressure on a warm day and force excess oil into the pump body.
