uh60crewdog
- Apr 23, 2014
- 6
Hello everyone, just registered today, I have a 1992 suntracker with a johnson/ nitro 150 outboard on the rear and currently can get it to crank. The last season ended with me having to tweek the wires going to the ignition switch under the dash to get it to go so I replaced switch, cleaned and reterminated the leads and problem persisted. now I can't even get it to turn over. The starter turns when the key is turned to start but no engine crank. I did notice that the oil warning alarm is wired into the ignition system and it looks to be in bad shape, could this be a culprit and can it be troubleshot/bypassed to see? not sure where to go from here, any help would be great , thank you...
