Johnson Motors
jimmbo
70 hp VRO Johnson, a blown 1984 thinking of purchasing 1997 70 hp VRO
Completely different Powerheads, and likely midsections. As for Gearcases, I never even looked, but unlikely to swap
Is this the engine I suggested you run from? Duplicate Posts on the same item are not the way to get info
gregandnancy
Sorry, I typed the first message and then my husband corrected me with the second message; yes it is the same motors we are speaking about. Thanks for your advice.
There was a change in top driveshaft spline at end of 1988 production year.-----There was a change to a different engine block in 1986 I believe.
Lower unit can be changed.----But you have to take both apart to swap the driveshaft.
