Re: johnson motor kills when put in gear
can you get it to go into gear by revving up the rpms a bit prior to shifting? may only be running on one cylinder and unable to operate under load. I would check the compression and spark. of course a good carb cleaning/rebuild is always good if it hasn't been done recently. does it stay in gear once you've managed to keep the motor running?
