Hey everybody I picked up a 1969 9.5 Johnson that hadn't been ran in a couple years. First I rebuilt and cleaned carb, replaced broken pull rope, new spark plugs and replaced rotted fuel lines. After doing all this the motor fired right up, I got the carb set and everything was good. After setting a few days I decided it was time to install back on the boat and see how it does in the water but before I did I tried to start it again just to make sure. The pull rope would not pull out, almost like the motor was locked up. I could turn the flywheel by hand but not by the rope then I notice a gas/oil mix coming out of a hole in the bottom of the lower unit. Things came up and I had to leave it for the day. The next day I tried again. Pull rope is pulling out fine now but the motor will not start. After a few pulls it starts leaking gas/oil mix out of the bottom of the lower unit again. I can not tell where the leak is coming from. I am a novice when it comes to any kind of engine but am pretty handy. The problem may be over my ability but any help would be greatly appreciated. Thank you for any response. Hopefully this is enough detail to get us started.
