Johnson lower unit interchangeable?
tashasdaddy
Re: Johnson lower unit interchangeable?
i sent a message to the guru. you aren't being ignored.
Gassman
I have a similar question does anyone know if a 1974 Johnson 50hp lower unit will work on my 1984 50hp johnson?
thanks
Ron
tashasdaddy
gassman no. there was a change from shift assist to mechanical shift, around 1978.
Gassman
Thanks for the reply, anyone know if a 1981 60hp gear box will work on my 1984 50 hp Johnson? Shaft looks the same, but no anode on the 60hp case,
Thanks Again
Ron
