Ok... so I bought a boat of my brother about a month ago and first time out on the water the 1986 - 20 hp Johnson lower locked up about a mile up river. I got it home and troubleshooting led to lower unit having 0 fluid in it and burning up. Apparently my brother forgot to refill it this spring before he said it was ready for water (he was moving to FL so sold me the boat). Ok... So that's my fault for not checking and my brother's fault for telling me it was ready for water.
Now, to today. The other lower unit was locked up and would not move a bit so I bought a Johnson 25 lower from ebay which was supposed to be off a 1992 25 hp. Upon pulling out of box, It came with a long shaft drive shaft. I looked it up and found you can just pull straight out and replace with shorter drive shaft. I didn't attempt to spin drive shaft prior to pulling out so I am not sure if it would spin, but was "grabby" at points on way out. I put the shorter propshaft in and went to put new water pump parts in and I found I can't spin the propshaft to install water pump impeller into pump.
I am not sure what's going on, but it sure doesn't want to move, even with a pair of pliers on the propshaft. Any help? Is something out of whack or by what I did or was this a bad lower off ebay? If it's something I did, what can I do to fix it?
