Johnson J90TLCIM Tach hook up
canadianguy1967
I have a older boat with this motor and the tack only has 2 wires, can i hook this tack up and where does it hook up? the one wire is black so i assume that is ground but not sure where the other wire is supposed to hook up to , thanks
emdsapmgr
The factory has already taken the tach issue into account. On the front edge of the control box, there is a 3-prong rubber plug, just under the key switch. That plug has a red wire (hot) a black wire (ground) and a grey wire, which is the signal wire to make the tach read. You have the option of purchasing a wiring pigtail from Bombardier which will link to the tach, or you can take the control box apart to access these 3 wires from the inside of the box. Almost all marine tachs will connect to this 3-wire system. (auto tach's won't work.) The back of the tach may have another (4th) wire for the light inside.
canadianguy1967
Thanks, I was told that by someone else also but my plug only has the one purple wire coming out going to the trim gauge. can I just open it up and take a wire form the inside? I have been looking aro8und to see any instructions on taking the control box apart, any help with that?
on the back of the tach, there is a black ground wire and a grey one. so this grey one would be I would assume the one needed to be hooked up.
F_R
You simply cannot assume you have a compatible tach. You need one that gets it's signal from the alternator. You may have one that gets it's signal from a magneto system, or a battery ignition system, a Universal tach, or even one of the highly obsolete CD ignition input signal type. IF you do have a compatible tach, the grey wire in the control box is the tach signal. That one plus ground. Some of those other ones I mentioned are kind of rare and valuable.
canadianguy1967
well it is the original matching tach with the speedo. Can I just run a jumper from that grey line at the control and temp hook up to see what it does? I would think if it is incorrect it may just damage the tach itself. Is there a way of checking the tach? i know I had it off the console and there is only 2 wires, no light on it either.
F_R
I don't think a temp hookup would damage it, but can't say for sure, especially since we don't know what you have. There is no switch on the back, right? All the more reason to suspect it is not an alternator tach. But it could be an old one. Does it have a name on it?
emdsapmgr
Sears just bought that tach from someone. I had an original like it on my 76 evinrude 3-cyl. I recall liking it, as it sported a Jeweled movement. Sort of like a clock.
Can't recall the company's name, but that one did have only two wires on the back. Probably hooked one up to the signal, and the other to ground. Forget just what I did. But it did work and give the correct rpm readings. I think the same company also made the early, early jeweled movement ski boat dual speedometers. High quality stuff in those early years. FR, you probably know the name of the original manufacturer.
emdsapmgr
The manufacturer of your tach was probably Airguide. You may be able to google that named tach and find out some info on how to connect it.
canadianguy1967
Thanks guys, going to try and hook up and see what happens. On the 3 pin connector, should there be a voltage or anything on that grey wire coming out?
