I have a 1993 25 HP J25RWET. What carbs should be interchangeable on this model ? Will a Recreational carb 93 thru 2002 be a direct bolt on ? I was told that most carbs from 93 to 2002 could be interchanged, does this hold true for the commercial line ? The tube that is in front of the butterfly in my carb is bent (previous owner) and I do not see this part listed in the rebuild kit , so I'm thinking of buying a replacement carb.
Thanks in advance for any help,
Zac
Zac
