And by keep it running I mean just a rapid put put put. I was told that a ball park rpm setting is to start the motor and as it idles, shift it into forward and reverse. If the motor doesn't stall out or jump like a scalded dog it's fairly close.
I got this motor awhile back. It was sitting out in the weather on the back of a boat for a year or two, still connected to the fuel tank. So the first thing I did (after I paid for it
) was clean and rebuild the carb. I put the carb back on and it absolutely will not start unless I hold that cam roller out just a hair. I'd really like to just get it starting reliably enough that I can back the boat down the ramp, start the motor and try to adjust the carb in the river with some back-pressure. Is this a reasonable plan of action?
And the other thing is the tiller handle is stuck. I can't rotate it at all. I took the handle apart and the interior was missing some of those little silver bits that ride in the grooves on the interior of the handle. The handle is dry and the groove is wallowed out, so that is a big mess as well.
