Johnson J150EXECD Carburetor float bowl replacement, nozzle well gasket?
pastorbud
[h=2]
I have 1998 Johnson 150 V6 150 hp looper that has fuel leaking from some of the carburetor bowls. From what I've read online, the only solution is to replace the gaskets AND the bowls, since the problem stems from the fact that the plastic bowls warp over time.
I am looking at the parts diagrams and wondering if in addition to replacing the bowls (Float Chamber 0433000) and the Float Bowl Gasket (0335070), should I also replace the Nozzle Well Gasket, #0343512 ?
[/h]
Chris1956
Honorary Supreme Mariner
PastorBud, I had the same issue with my motor (same year and model as yours), last spring. I cleaned the carbs and replaced all the gaskets and bowls.
Look around for the best price on the bowls and make sure you get the right carb gasket kits. There are kits listed for your motor that do not contain all the gaskets that fit your carbs.
Also, if you do not remove the idle mixture needle, you can still clean it, via the pocket cover, but wont need to adjust it.
pastorbud
Thanks. Looks like nozzle well gaskets are cheap anyway. So, it looks like 6 bowls, 6 bowl gaskets and six nozzle well gaskets.
Chris1956
Gee, what about carb base gaskets, calibration pocket gaskets and main jet gaskets? You will also need to move the main jets over to the new carb bowls.
Faztbullet
These bowls do warp but not as much as the crossflow model, most leaks are around the BB in bowl passage.. You need the complete gasket kit and these do have a torque spec and torque sequence, they do not use a gasket under inlet needle seat.
Bannister 6905
I have a 1995 Evinrude 150 Intruder that I recently purchased that also had the leaking carb problem.
My carbs were leaking from around the float bowl gaskets and from the steel ball that was pressed into the float bowl (to close off a drilled passage).
The leaking apparently had been going on for a long time, because of the amount of oily residue that had collected inside the engine and on the garage floor. Fuel mix was literally dripping from the trim tab anode...
After much investigation in on-line forums, I decided to remove the carbs to check two things:
* are the float bowls warped?
I used a straight edge and quickly determined that each of the 6 float bowls was warped - some some more than others, but all were warped beyond the gasket's ability to seal them to the carb body. Rather than purchasing new bowls, I decided to try to sand the sealing surface to remove the warp. I used a sheet of 100 grit sandpaper, fastened to a flat surface and began to carefully 'polish' each float bowl. I stopped when I saw sanding marks across the entire sealing surface. I then rechecked each bowl with the straight edge and resanded, if I saw warpage. Some of the bowls took several passes to finish.
Next, I thoroughly cleaned each bowl using spray electronics cleaner (will not attack the plastic used in the bowls) and blew each out thoroughly with compressed air.
Next step:
* reseal the steel balls with ?
After cleaning each of the recesses where the steel balls are (again using electronics cleaner and compressed air), I mixed up a small amount of epoxy (I used JB Weld) and applied liberally to the orifices where the steel ball sits. I made sure to force the epoxy as deeply as possible into the cavity and also made sure that there was a slightly domed area left over the cavity when done. I left the float bowls sit overnight to fully cure.
After 24 hours, I reassembled all 6 carbs, and did not use new gaskets, since the old ones felt very pliable. I did use a torque wrench to make sure I did not over tighten the bowl to the carb body (I believe 25 in/lb) and the carb flange to the engine (45 in/lb). I did use the recommended "special" Phillips-like bit to tighten the screws. After assembling, I let the engine sit for another 24 hours, just to be sure the epoxy had fully cured.
Finally, I reattached the fuel line to the pump and filled the float bowls, using the bulb.
Viola - NO LEAKS.
I then let the motor sit again overnight and checked for leaks - NO LEAKS.
I trimmed the motor up to create a worst-case situation and NO LEAKS.
6 weeks later and several trips to the lake later, NO LEAKS.
Total cost of this repair was ZERO, since I already had the electronics cleaner and epoxy on hand. Actual labor time was about 4 hours over the course of 3 days. I work very methodically.
As to why the float bowls were warped, I think they were overtightened at some point. The leaking steel ball issue looks like an incorrect adhesive / sealant was used initially from the factory. I can't say if Ethanol or carb cleaner use contributed to this failure.
This method may not work for everyone, but it sure did for me and saved me a lot of $$$ and provided great satisfaction with a motor that runs fantastic with NO LEAKS.
Bannister
pastorbud
Thanks for the info! Still working on getting it cleaned up and working enough to do a compression test before I tear into the carbs.
Bannister 6905
You're welcome.
Remember, leaking carbs are not only a performance issue, but definitely a safety issue (fires).
A tip - when it comes time to do the carbs, you can simplify the task by removing only the first section of the carbs. There's no need to remove the fuel manifolds. You can also check the fuel hoses at this time and replace any that have hardened or show cracks, etc.
Bannister
