Johnson J115PLSIG shift shaft height
Kevin Long
Good evening gents, changed the water impeller a week ago and tried about 10 times to reinstall gear case but shift shaft will not reach pin to reattach.My manual says height of shaft should be 21 1/4". Is this the correct height in neutral to top of gear case ?
The air silencer says V4 looper and upper gear case stamped V4 eagle Ficht
Thanks in advance
Kevin
