johnson id 225 need help
osprey341
helping a friend get his boat running. when he bought motor was told it was a1989. he thinks he might have put a power pack on the motor. the part number comes back as 1991. he never got engine running right. and boat sat for ten years . no id tag no serial number . the number on freeze plug g2534962 which comes up as no match . power pack and stator has two different part numbers 1991 or 1989. any help point me in direction of id model of motor would be great. motor acts like it has a bad vacuum leak revs to high and when it settles down cough and dies . carb cleaned and sync fuel pressure is fine and i have no leaks vacuum. timing is very close but motor doesn't run well enough to dial in. also magnets where al loose on flywheel have repaired them . stator is got the brown jell bleeding out of it needs to be replaced . before i start buying parts need a year and model or just wasting money.also compression 90# al 6 cylinders. my thought is he put wrong power pack on and never got it to run right . thanks my first time here.
