I have what I think is a 72 Johnson Hydroelectic 50hp outboard motor. Me and a buddy have been working on this motor for about 2 weeks and we had it running and everything was going good except the motor would only go in reverse. So we took the shift box apart and noticed the spring in the electric shift was gone and the casing was cracked. This is a pollak shifter with an arm that moves back and forth as you move from reverse to forward with reverse putting the arm in the forward position.
So we started our search to find a replacement and found nothing. After searching forums, we came across a post in here detailing a way to hook up duel toggle switches and bypass the electric shift all together. We thought great, and went out and got a 2way and 3way toggle switch. We followed the guide to a tee and hooked up all the wires. Purple to the middle, green to the front and back , and then the green spliced onto the 2way toggle with the blue going straight to the 2way toggle.
After all this was done we tried to start the boat and the engine won't turn over. Now, it was starting and running great before but with the broken shifter out and the toggle switches in, it won't start. The choke gets power but were not getting power to the starter. We tried charging the battery, we put the broken shifter back in and are out of ideas as to why it won't start.
Any help anyone could give would be greatly appreciated. Thanks in advance to anyone that able to help us figure this out.
