johnson gt150 starter problem
mattu
starter bendix comes out of flywheel before engine starts can anyone help me with this?
Will Bark
Re: johnson gt150 starter problem
Make sure all battery and solenoid connections are clean and tight; they need to be shiney bright. Is battery fully charged?
boobie
You may also have some ign probs with the mtr where the mtr doesn't fire on all the cyls when starting and "fools" the starter mtr telling it to kick out.
emdsapmgr
Jump start the starter with a set of automotive jumper cables to a battery that is know to have a good charge. If the starter performs normally, you may have a bad solenoid.
That happens when motor fires and then dies, sometimes due to inadequate choking. Choke the crap out of her, and see if that helps. If she won't fire while being choked, let off on the choke, and she should fire and hopefully start right up.
mattu
thanks for the advice will try those things. thats what i was thinking. its an 88 or 89 ranger does anyone know where the solenoid is located? only happens when motor is cold, starts fine once it warms up.
