Background: I have a pair of 300's acquired for an offshore fishing project. However, I subsequently understood they have not proven particularly reliable so I thought I might use them for an inland waters project. I am seduced by their potential hp:weight ratio.<br />There is a lot of knowledge and experience on this list so a best guess here might be useful/reliable as I am not very experienced with two cycle engines.<br />Question: Since there is no crankcase oil sump, can these vertical shaft engines be inclined to near horizontal for a direct drive? I think they could be adequately aspirated, cooled and exhausted, but my concern is fuel/lube flow. At first blush, the crank might be 'better' positioned for gravity lube (horizontal and down...ie, carbs up) but what do I know? I have seen a throttle body injection system advertised with computer tuning/timing. Anyone with any experience with these? Could one of the new (presumably more reliable and efficient) 2 cycle systems be retrofitted? Rendering this alternative-use idea unnecessary and undesirable. <br />Wrap up: I have very little in this pair of motors so I can experiment a little. As I appreciate it, these motors are a bit of an urban legend...but did not perform well on the racing circuit. Exhaust gas temp probes in each side and removal of the VRO feature seems mandatory before exploring combustion chamber clearance, fuel mixture changes and non-rev limited power pak. <br />Any Ideas or Suggestions?<br />1. Retrofit a more modern fuel delivery system?<br />2. Horizontal orientation problems?<br />3. Experience with aftermarket fuel delivery system conversions?<br />4. Creative suggestions for a winter project?<br />Thanks in advance.<br />b.line
