My 9.5 Johnson leaks gear oil through the exhaust while stored lying on its back with the prop & cowling housing facing down. The lube is not coming from the prop shaft seal and it only leaks if the engine is positioned as described above. It was stored in that position approx 1.5 yrs before the leak started. Have replaced the lube but it leaks back out again. I want to start using this engine again but don't want to put it in the water till I repair the leak. Any suggestions? 9R-69S
