Johnson fast strike 150. “Knocking”
Jberry78
I have a Johnson faststrike 150 that has been a GREAT motor. This weekend I noticed it was “knocking” while running down the lake. I did a compression test when I got home and here is what I found
1-115 psi
2-110 psi
3-115 psi
4-105 psi
5-85 psi
6-95 psi
so what should I do? Obviously there are problems with chl 5 and 6, what do I need to check first? Is it going to hurt it more to keep running it like it is until winter so I could do it then?
Honorary Supreme Mariner
No need to kid yourself.----Time to remove cylinder heads or inspection.-----It is only going to get much worse and more expensive if you keep running it.
Faztbullet
Rebuild time.....And pressure test block first before spending any $$$
Rustywrench
Just for the future as you are getting good advice. Looks like #5 is in trouble? It is not abnormal for compression to vary from bank to bank (#1,#3,#5 vs #2,#4,#6) right side vs left. It is also designed into the engine that number #5 & #6 have less compression than the other 4 cylinders. That might explain #6, but it doesn't explain #5. Too much loss there compared to other two on that side. I only bring all this up because after you rebuild (if you do?) compression will still be uneven on the two bottom cylinders. This motor has staggered combustion chambers in the heads. Many motors have been rebuilt because people have been told compression was uneven on bottom cylinders.
Find someone who can pressure test this block before you spend money on rebuild. Not a big money expense, but you need to know it is OK before you proceed.
Bosunsmate
Why was there lower compression designed into the two bottom cylinders and how did they do that? Milled the head some more?
Jberry78
Yea, I was afraid it was time to rebuild, what exactly is the pressure test? Also I would like to do some of the work myself to save a little money, I’m assuming I can disassemble and take the block to machine shop to bore out, then I would replace pistons and rings? Or is it something that I just need to have a marine mechanic do it all?
Faztbullet
Has to due with exhaust runners and heads are milled at a angle..more cc on bottom
Rustywrench
Not exactly. If you pull the spark plugs & look at the recess that is machined for the plugs to sit in you will notice the recess is less in #5 & #6. The floor of the combustion chamber is deeper making for less compression therefore the recess can't be as deep or it would weaken the threaded area. Just a quick way to tell. The regular 150EL model does not have these heads, just GL & SL. It does have to do with tuning. The shorter exhaust tracks for those cylinders don't need as much compression or you can look at it as the others having more?
Rustywrench
Pressure testing requires some dedicated plates & thick rubber. It's not hard, but a lot of expense for just one test. Some dealers have put together the equipment, but you have to build a lot of powerheads to justify it. About $65 dollars for a test last time I checked?
Jberry78
Thanks for the input, I’m going to look into getting it pressure tested, I went ahead and de Carbed it today, it didn’t appear to be bad, I guess if the pressure test shows to be good, then it’s time to remove the head covers and see how bad the cylinders are??could they just need a ring job, or is it usually best to just bore out and put oversized pistons in??
