Johnson evinrude automatic choke
smithbader
Today I managed to break off both of the platic hose connectionc on the end cap on my automatic choke. where can I get another? Do I need to purchase the entire sylnoid or can I buy just that end cap. It has a large M on thr end cap.
F_R
Honorary Supreme Mariner
Re: Johnson evinrude automatic choke
It sure would help if you gave the model number, year, horsepower, or something to go on. Taking a wild guess, I think you might be talking about the primer solenoid. Just grabbing one at pure random, a 1984 35hp electric start, has a replaceable primer cover, Sierra Marine part number 18-0993, should be available here at iboats. OEM number is 437228
smithbader
Sorry about that. it is a 89 johnson 100hp outboard. Gonna try your idea on the primer cover. thanks so much for the help!!!
smithbader
The one you suggested has the 2 out barbs for the carbs but I didn't see the barb coming from the carbs. Can you suggest another one? It's a 89 Johnson 100hp. thank you.
boobie
Don't know what you mean by barbs coming from carbs. Aren't the fuel lines still attached to the cap off of the primer??
